Install openVPN server on F2-210
marco.ghirlanda
Post by marco.ghirlanda »
Dear all,
thank in advance for your help.
My problem is taht I need to enter remotley into my NAS using a VPN, and I tought to use openVPN, because I an confident with its configuration.
In this way I coulb be able to access to my stored files using the file explore (like as when I am connected to my LAN) even when I am conneted by remote.
The native remote access is useful if it is used like dropbox or similar services, but not very useful to work on files remotely.
Someone have a solution?
Other question regards the way to install packages there are not in the official store.
Suincerely.
Marco.
Re: Install openVPN server on F2-210
Hi Marco, very sorry ,the F2-210 model does not support VPN.
Sorry to tell you that we donot have plan to add VPN Server for ARM 210 series models.
bidmead
Post by bidmead »
themardy/openvpn is an available OpenVPN docker with an ARM64 version. Won't this do the job?
Chris
