[Discussion] Network Monitoring Overview (Bug?)
rfbjr
Post by rfbjr »
The network display status doesn't scale to the speed. 254meg is off the chart (which only shows up to 100meg)
It does display correctly for Disk status
I'm running an RSYNC between the F4-424 Pro the F6-424.
The LAN2 network is 2.5ghz all the way, on a separate 2.5ghz switch. All the devices I have all use the 2nd NIC as a private backup network.
F4-424 Pro also at 7.0.0777
D4-320
TMnight
Re: [Discussion] Network Monitoring Overview (Bug?)
Post by TMnight »
Thank you for your feedback. We have successfully reproduced the issue in our lab and have arranged a fix. The relevant improvements will be released in a future TOS 7 update.
Please keep an eye on system update notifications. Thank you for your understanding and support!
rfbjr
Post by rfbjr »
Thank you
D4-320
Return to “System Resources”
