New F2-425 Plus - Installation and musings
This forum serves as a free discussion zone, intended to facilitate community conversations on topics unrelated to TerraMaster products and services.
Sunday:
Received my new F2-425 Plus - Thanks Terra-Master 8-)
{I had decided to set this up as a "new" device rather than transferring from an older machine.
Naturally this put a bit of a strain on finances given the current situation and pricing. However,
I was able to find some "new, old stock" Crucial P3 nvme. 2 x 500GB would replicate my F2-424
setup - These are adequate for the '525+' as it still only uses Pcie Gen3 over 1 lane for the nvme drives.
Also found a couple of used Seagate 6TB Exos drives. Not used this type of drive before (used HGST in the -424),
so interested to see how they go. (They seem just as noisy as the HGST :o )}
Monday:
I had previously retrieved a copy of a TOS7 installation file (v .0403) that had been linked in another thread. SO, lets try a direct manual install of that! Smooth as silk :P
Initially I just installed the nvme drives (Traid mirror). Setup the o/s and Volume1 on these. Once I was happy
everything was working, performed update to v.0408 (latest at the time). I then installed the pair of HDD (again, Traid mirror), as a second storage pool and 2 Volumes.
Then just let the nas do it's thing and by about midnight the drives/pools/volumes were sync'd.
Tuesday:
New Tos7 update. (Time to retest Filesystem snapshots). Install some applications and copy over some files. Network
is only running at 2.5Gbe so the higher speed ethernet adapters are a bit wasted for me. No intention of updating network switches (again!) in the near future and, if I did, I would go for 10Gbe unless 5Gbe becomes more viable (I doubt).
Phil
Re: New F2-425 Plus - Installation and musings
Post by Phil »
Thank you for sharing your detailed experience of unpacking, setting up and using the F2-425 Plus! Your practical considerations on hardware selection and network environment are of great reference value to us and other users.
If you encounter any problems or have new discoveries during subsequent use, you are welcome to continue the discussion on the forum at any time.
Wish you a pleasant use!
Return to “Lounge and Boast”
