TOS 7.0.0465 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @snapsh0t, @Phil, @Gremlin, @samius, @rfbjr, @DanB, @Lex, @bartmans99, @Nitrokalel, @mmalchuk, @usersky, @EgorA, @BFG and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixes:
1. Fixed the issue where file system snapshots could not be successfully taken under specific conditions.
2. Fixed the issue where the real-time display of application status might be abnormal when operating multiple applications simultaneously.
3. Fixed the issue where an extraction failure might be prompted when updating the system.
4. Fixed the issue where the USB Copy auto-mount function did not take effect.
5. Fixed the issue where the status display might be abnormal during VPN connection.
6. Fixed the issue where the text editor did not display the correct prompt when editing a read-only file.
7. Fixed the issue where some application shortcuts redirected to incorrect pages.
8. Optimized the page display of custom DDNS.
9. Fixed some other known issues.
Warning:
1. If the first update prompts a decompression failure, please click update again.
2. To reduce interruptions caused by system notifications, we have readjusted the triggering rules for notifications at various levels and simultaneously modified the default system notification settings. After the update, you will need to reconfigure your personal notification preferences.
3. Due to the kernel architecture upgrade in TOS 7, the VirtualBox application will no longer be compatible with subsequent versions and will be removed from the App Center.
We recommend that users who still rely on this feature migrate their existing virtual machines to the officially supported VMs (Virtual Machines) application to ensure continued functionality.
For migration instructions, please refer to the technical documentation: https://toshelp.terra-master.com/faq/category/vms
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.520 for Windows OS.
2. Download TNAS PC 5.2.520 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.520 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
Note:
Update Notes
Bugs fixes:
Warning:
Update Procedure:
Client Downloads:
Re: TOS 7.0.0465 Beta (X86) is Released for Update
Updated. No issues.
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
1 X 2TB (SSD) Hyper Cache
Update applied:
F2-221
F2-425+
Note: Still seeing instances of error(s) "Failed to retrieve data" (or something like that) flash across the screen after
update (reported as successful). This happened on both units.
'dmesg' continues to report multiple instances of
I don't know if this is a cause.
A separate reboot post-update also shows error on GUI refresh (-221 checked so far)
Edit:
F2-425+ "Failed to retrieve data" error also appears after installing backup applications 'TFM' & 'USB Copy'
F2-221
F2-425+
[ 2944.884328] systemd-gpt-auto-generator[18186]: EFI loader partition unknown, exiting.
[ 2944.884335] systemd-gpt-auto-generator[18186]: (The boot loader did not set EFI variable LoaderDevicePartUUID.)
[ 2946.680553] systemd-gpt-auto-generator[18236]: EFI loader partition unknown, exiting.
[ 2946.680560] systemd-gpt-auto-generator[18236]: (The boot loader did not set EFI variable LoaderDevicePartUUID.)
[ 3228.948585] systemd-gpt-auto-generator[19659]: EFI loader partition unknown, exiting.
[ 3228.948592] systemd-gpt-auto-generator[19659]: (The boot loader did not set EFI variable LoaderDevicePartUUID.)
[ 3229.212164] systemd-gpt-auto-generator[19704]: EFI loader partition unknown, exiting.A separate reboot post-update also shows error on GUI refresh (-221 checked so far)
Edit:
storageninja
Hello TM after every update the SSH id is changed and my SSH software complain about that? I reported earlier some issues with the SSH identity, could you take another look into this behavior?
Update applied to all. The F4-424 Pro was the easiest update in a long time.
Filesystem Snapshot now purges the oldest if retention period has been reached and a new snapshot is created.
Also, I noticed this, well actually it was on v448: TNAS System Notification from Forge (The emails generated now include the device name)
Other testing will proceed during the day here.
F6-424 & F4-425 Plus at 7.0.1341
F4-424 Pro (x2) at 7.0.1341
Где можно скачать?
My F2-221 and F5-221 updated from 0427 to 0465 smoothly.
External USB StoragePool and Volume came back to life without probs.
Thumbs up!
Thumbs up!
F5-221 - TOS7.0.1341 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1341 - 2x3TB JBOD - 1x4TB Single USB
Your feedback is well received, we will forward it to our product team and formulate a solution promptly. Thank you!storageninja wrote: ↑24 Mar 2026, 20:13 Hello TM after every update the SSH id is changed and my SSH software complain about that? I reported earlier some issues with the SSH identity, could you take another look into this behavior?
I got the same messages on my F2-425+ when logging in after the update.
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
