[Help] TerraMaster D5 Hybrid needs physical reconnect after Linux reboot
tvdruenen
Netherlands
Post by tvdruenen »
Hi!
I have a D5 Hybrid attached over USB-C directly to a server running Fedora 34. Everything works smooth and fast.
The only downside is that, when I reboot the OS, the D5 Hybrid doesn't get recognized afterwards.
The device its lights stay on, disks are running, but the OS can't find it at all.
I need to manually unplug and plug the USB-C cable for the device to start working again. So it seems the device is in some kind of weird state.
This is after a reboot:
lsusb -t
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 002: Dev 002, If 0, Class=Communications, Driver=cdc_acm, 12M
    |__ Port 002: Dev 002, If 1, Class=CDC Data, Driver=cdc_acm, 12M
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 480M
    |__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/5p, 480M
        |__ Port 001: Dev 003, If 0, Class=Billboard, Driver=[none], 12M
        |__ Port 005: Dev 004, If 0, Class=Billboard, Driver=[none], 480M
/:  Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 10000M
When I unplugged and plugged the device again, this is the output:
lsusb -t
    |__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 480M
    |__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 10000M
        |__ Port 001: Dev 003, If 0, Class=Mass Storage, Driver=uas, 5000M
        |__ Port 003: Dev 004, If 0, Class=Mass Storage, Driver=uas, 10000M
        |__ Port 004: Dev 005, If 0, Class=Mass Storage, Driver=uas, 10000M
This is weird behavior, I tried different USB hubs and hard disk drives, and they all seem to be available after a reboot.
I also tried regular USB-2 HDD's attached to a USB-C hub and attached the hub to the USB-C of the server. Also works.
So for some reason this behavior of the D5 Hybrid where it stays unconnected after a reboot is very specific for that device, and not seem related to server hardware or OS.
tvdruenen
Netherlands
Re: [Help] TerraMaster D5 Hybrid needs physical reconnect after Linux reboot
Post by tvdruenen »
This issue seems to only occur when using an USB-C to USB-C cable in my setup. I tried using a proper USB-C to USB-A cable, and this solved the issue.
A proper USB-C to USB-A cable (5GB/s ~ 10GB/s) is still fast enough for my setup.
TMjack
Post by TMjack »
We would like to confirm whether the original Type-C to C cable included with the D5 Hybrid product has the TERRAMASTER brand logo and the 10Gbps marking printed on both connector ends.
Return to “USB Series”
