Photo backup from Mobile to TNAS like syncthing  [Accepted]
nperiannan
India
Post by nperiannan »
I believe this may have already been raised and clarified earlier. However, I am experiencing issues with the photo backup feature in the mobile app. The backup process is extremely slow or often does not occur at all, particularly when the mobile device is not on the same local network where the TNAS is configured.
Even when the mobile device and TNAS are on the same network, the photo backup does not consistently work as expected. In most cases, I have to manually open the app to initiate synchronization, and it takes a considerable amount of time just to complete the sync process before it begins uploading photos from the mobile device to the NAS.
In comparison, other synchronization solutions like "syncthing" handle this more efficiently—automatically syncing photos to the server as soon as they are created, regardless of whether the device is on a local or remote network, and without requiring manual intervention.
It would be helpful if the photo backup functionality could operate in a similar seamless and automated manner.
Re: Photo backup from Mobile to TNAS like syncthing
The initial backup may take a considerable amount of time for alignment and preparation. Additionally, extra processing is required during backups depending on various circumstances. We understand your anticipation for increased backup speeds and will strive to continuously optimize and enhance the application.
TMtina
Post by TMtina »
nperiannan wrote: ↑15 Mar 2026, 20:55
Which version of TNAS mobile are you currently using? We recommend upgrading to TNAS mobile 3.5 Beta to experience the backup feature, as this version has been optimized for the backup process.
Download instructions:
Android: Click to download the installation package directly
https://download3.terra-master.com/Apps ... .5.053.apk
iOS: You must first install TestFlight, then join the test via the following link
https://testflight.apple.com/join/wFWYABJS
nperiannan
India
Thank you for sharing the beta version of the mobile application. I will test it and provide feedback shortly. Currently I am using 3.4.xx build.
Could you please let me know if there is a dedicated post or channel for this beta app where the latest builds are published as they become available, leading up to the general availability (GA) release?
Phil
Post by Phil »
According to the current release schedule, the latest versions of the TNAS Mobile (mobile) and TNAS PC (desktop) software are usually released along with the official forum posts for the TOS system updates.
That is to say, you can check the relevant posts about TOS system version updates on our official forum. In the post content, there will be download links for the latest versions of these two companion software.
If you encounter difficulties in finding a specific version or have other questions, please feel free to raise them on the forum at any time. We will do our best to assist you. Thank you for your attention!
nperiannan
India
Re: Photo backup from Mobile to TNAS like syncthing  [Accepted]
Thank you for the info, Got it.
thomass112
Australia
Post by thomass112 »
If you want Syncthing-style behavior specifically (fast, low-resource, reliable auto-sync) rather than sticking with TNAS Mobile's native backup, running Syncthing via Docker directly on the TNAS is the more solid route: install the Syncthing container through TOS's Docker support, set up a shared folder pointed at your desired NAS destination, then install Syncthing on your phone (via F-Droid or Play Store) and pair the two devices using the same folder ID, this gives you real-time, delta-only syncing without TNAS Mobile's inconsistent background-backup and timestamp issues that keep coming up in other threads here, the only trade-off being you lose Syncthing's own photo viewer, so you'd browse backed-up photos through TOS's file manager or Terra Photo instead.
