TOS 7.0.0427 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @JSCFORCE, @snapsh0t, @rfbjr, @mokagino, @Joesh, @star, @Gremlin, @joka388, @luismartin, @OttO1916, @AlexanderSO, @mnewland, @ARThornicroft, @bypc100, @mmick, @foxfordf0r3v3r and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs Fixes:
1. Fixed an issue where Fedora 43 could not log in to TOS via SFTP.
2. Fixed an issue where scheduled tasks for applications might not be displayed when exceeding the system’s scheduled task list.
3. Fixed an issue where disks in an external hard drive enclosure might not be recognized properly after a restart.
4. Fixed an issue where USB devices could not undergo performance testing.
5. Fixed an issue where traffic control rules for SMB interfaces could not be created.
6. Fixed an issue where an error might be prompted when editing read-only files with a text editor.
7. Fixed an issue where clicking "Enable Media Indexing Now" in Photos might not navigate to the correct page.
8. Fixed an issue where the operation button for the bad block scan function might not be grayed out when selecting multiple disks simultaneously.
9. Fixed other known issues.
Warning:
If the first update prompts a decompression failure, please click update again.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.510 for Windows OS.
2. Download TNAS PC 5.2.510 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.510 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
snapsh0t
Re: TOS 7.0.0427 Beta (X86) is Released for Update
Post by snapsh0t »
Updated my F2-425 Plus and there are no obvious problems.
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
My F2-221 was updated with no apparent problems.
jpeckinp
Post by jpeckinp »
Disk hibernation is back on by default again.
Thanks for fix #3
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
rfbjr
Post by rfbjr »
UPS Information, no idea if this happened with prior releases.
First the actual NAS (F4-424 Pro) with the UPS attached via cable.
Second (F4-425 Plus) and third (F6-424) via Network
Why does the F4-425 Plus report a different and actually higher remaining time seconds?
F6-424 & F4-425 Plus at 7.0.1341
F4-424 Pro (x2) at 7.0.1341
rfbjr wrote: ↑12 Mar 2026, 18:41
That's odd.
I have UPS server running under Tos6 and 2 clients under different versions of Tos7. All report the same 'time remaining'.
Joesh
Indonesia
Post by Joesh »
So far the problem I experienced on version 7.0.408 is gone after updating to this version.. Thanks for TerraMaster Team for the TOS and TNAS PC update
rfbjr
Post by rfbjr »
Didn't think I needed to check but all three (F6-424, F4-425 Plus and F4-424 Pro) all have disk hibernation back on after this release (427)
rfbjr
Post by rfbjr »
In the initial post of this release, there is this: " Fixed other known issues" (it would be better if the other known issues just had a link so someone can go look in more details)
If I don't see a specific issue that has been called out as being fixed, should I just re-test any issues I have found and submitted?
For Example:
Recurring rsync jobs, don't generate status/email messages (yes it is turned in notifications) or display any info on the completed task, start/stop times and data transmitted.
MikeZhang
Post by MikeZhang »
rfbjr wrote: ↑13 Mar 2026, 03:00
It's welcome to report any issue you meet and we will try to reproduce and find solution to fix
