Solar battery BMS
ychanke
Solar battery BMS
Post by ychanke »
I have solar panels with BESS batteries at home. The BMS of battery can be connected by Blue tooth or ethernet cable. I wish there is an app in Terramaster capable to communicate with BMS and export data to phpAdmin. Then, I can read the battery info online with web server.
Re: Solar battery BMS
Your requirements have been added to the project list and are awaiting review and discussion.
Perhaps you could discuss implementing it through Docker containers.
If you are using TOS 6 or a later system, you can try to install and use it via the terminal.(Ubuntu-like environment)
Dear Customer,
Thank you for taking the time to share your suggestion with us.
We regret to inform you that, after careful evaluation, we are unable to adopt your proposed feature at this time due to various considerations.
We would like to point out that an open-source solution is already available within the Docker ecosystem. You may consider installing and running the BMS data collection application via Docker as an alternative approach.
We truly appreciate your understanding and continued support.
