F5-221(TRAID, Shutted) to F6-424
This forum serves as a free discussion zone, intended to facilitate community conversations on topics unrelated to TerraMaster products and services.
cipe91
Italy
Post by cipe91 »
Hi all,
as title im looking how to make swap from a F5-221 with start issue to a new F6-424. I can/want mantain TRAID mode if it is better for fast transfer.
How i can do? i can simple put old drive into new nas and start it?
Thank for help,
J
F5-221
MikeZhang
Re: F5-221(TRAID, Shutted) to F6-424
Post by MikeZhang »
cipe91 wrote: ↑04 Mar 2026, 02:53
1. Please check your system partition size under control panel>overview>"/", if it's 2GB, please back up data first, or use M.2 SSD to set up F6-424 then insert old disks from F5-221 then old data is accessible.
2. If it's 8GB, the F5-221 uses Legacy boot mode, while the F6-424 uses UEFI boot mode. Since hard drives cannot be directly inserted and used between NAS models with different boot modes, reinstallation of the TOS system will be required in such cases. During this process, data will be retained, but system configuration will be erased.
Return to “Lounge and Boast”
