[Discussion] F4 SSD and Seagate Firecuda 530R SSD
Ot002
Hungary
Post by Ot002 »
The Seagate Firecuda 530R SSD is not on the official compatibility list, still i plan to buy it for my F4 SSD. Will it work fine?
crisisacting
Re: [Discussion] F4 SSD and Seagate Firecuda 530R SSD
Post by crisisacting »
It'll likely work fine, however it's restricted to PCIe Gen3, either by ×2 or ×1, depending on which slot is used.
MikeZhang
Post by MikeZhang »
Ot002 wrote: 03 Mar 2026, 04:35
This model is not tested and verified, to ensure the best possible compatibility and stability, we strongly recommend that you refer to our compatibility list.
