5Gbps Ethernet USB adapter  [Accepted]
EnchongG
Philippines
Post by EnchongG »
Hi
I’m a new user of the F2-425plus running TOS7, and I’d like to know if anyone has used a compatible 5Gbps Ethernet USB-C adapter with the Realtek RTL8157-CG chipset. Does it work? If so, could you provide a step-by-step tutorial on how to set it up? Thanks.
MikeZhang
Re: 5Gbps Ethernet USB adapter
Post by MikeZhang »
EnchongG wrote: 02 Mar 2026, 15:46
Please open TOS terminal and enter this command "ls /sys/bus/usb/drivers" to check if adapter driver is supported or not
EnchongG
Philippines
Post by EnchongG »
MikeZhang wrote: 02 Mar 2026, 16:35
Thanks for quick response, this is what i get when i type the command
EnchongG@LorTNAS:/# ls /sys/bus/usb/drivers
cdc_ether cdc_mbim cdc_ncm cdc_wdm hub rtl8812au rtl88x2bu uas usb usb-storage usbfs
MikeZhang
Post by MikeZhang »
EnchongG wrote: 02 Mar 2026, 17:31
It is supported, you can enter following commands to install driver for it
1:
apt update
2:
apt install linux-firmware
EnchongG
Philippines
Re: 5Gbps Ethernet USB adapter  [Accepted]
Post by EnchongG »
Thanks, this thread can be closed.
