[Help] Volume1 was full => restart NAS => Volume1 displayed corrupted
ind57
France
Post by ind57 »
The volume was full and TOS 6 became read only
I wasn't no more able to delete snapshots
I then restarted the NAS
Then the Volume1 was displayed as corrupted => does it mean that all my 5,3TB data are lose?
when I try via ssh to remount Volume1:
...@TNAS:~# sudo mount -o rw,usebackuproot,nologreplay /dev/mapper/vg0-lv0 /Volume1
mount: /Volume1: must be superuser to use mount.
...@TNAS:~#
==> I think Volume1 is not corrupted but TOS cannot mount it
How can I mount Volume1 at least to retrieve all data please?
NAS SSD 8 plus with 4 SSD of 2TB
TOS version 6.0.794
Thanks in advance for your help,
ind57
Felix
Re: [Help] Volume1 was full => restart NAS => Volume1 displayed corrupted
Post by Felix »
The initial account created on the NAS for SSH login is a super administrator with full privileges. You can execute commands directly without ‘sudo’.
ind57
France
Post by ind57 »
Hello Félix,
Thank you for your answer.
The user I use is the initial one. I don't understand why thèse commabds does not work.
any idea ?
which commands to remount it at least to retrieve and backup data ?
regards
ind57
France
Post by ind57 »
maybe my initial account is corrupted due to this topic:
viewtopic.php?t=8140
I have no other idea to be able to retrieve this account in order it become again super administrator.
Regards
Felix
Post by Felix »
ind57 wrote: ↑01 Mar 2026, 11:49 maybe my initial account is corrupted due to this topic:
Regards
You can use this command to mount: mount /dev/mapper/vg0-lv0 /Volume1
jaguera
Spain
Post by jaguera »
Good morning,
I have the same problem. The root directory was full. After reading on the forum, I deleted files via SSH and restarted. When I opened it, I found all the volumes corrupted. I have an F6-424 Max with two 2TB NVMe drives (system) and two 22TB mechanical drives (data).
What can I do to fix it? Should I delete the volume and recreate it from the TOS interface? Would I lose any data?
jaguera
Spain
Post by jaguera »
jaguera wrote: ↑10 Apr 2026, 18:33 Good morning,
Nada, ya lo he solucionado usando la IA. No he perdido los datos, pero he tenido que instalar y configurar muchas cosas.
jaguera wrote: ↑11 Apr 2026, 06:28
We will try our best to help you solve the problem.
The symptoms visible on the page alone are not sufficient to pinpoint the issue. We recommend that you generate a system report and send it to our technical support email address for analysis.
(TOS Desktop > Technical Support > Report Issues)
ind57
France
Post by ind57 »
Hello Jaguera,
Personaly I have sent the system report and received absolutly no answer...
In order to retrieve my data, I create a linux bootable usb key and launch the NAS from it. Then I mounted the volume on this linux and retrieved my data to my PC (chatgpt and gemini are your friends). And then I reinstalled the NAS.
Good luck...
ind57
ind57 wrote: ↑11 Apr 2026, 19:12
Emails are not usually processed or replied to immediately. Please be patient.
We will try to locate your email directly.
