[Help] Copying snapshot to remote NAS
rfbjr
Post by rfbjr »
Everyday I have this filesystem take a snapshot, keeping only 3 occurrences.
Later in the day I rsync the snapshot contents to another NAS (safekeeping if you call it)
Target folder (remote nas)
So my question or problem is, without manual intervention I want to the target folder to only contain what is in the source.
Is there an option on the RSYNC gui to do that?
What I am attempting now is to script what I thought was a simple rmdir of folders older than 3 days to be purged.
Here is what I'm using
It doesn't work. No visible errors, even running manually in the terminal window. If you look at the folders in terminal window, there is external security on (SETACL). Do I need to remove that first then attempt whack the folders?
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
Re: [Help] Copying snapshot to remote NAS
I don't know if this is relevant, but in many linux derivatives '-ctime' (creation time) is a nebulous concept and not always recognised. Take a look at '-mtime' (last modified).
Frustrated Beta Tester!!!
rfbjr
Post by rfbjr »
I should have mentioned that I did try mtime as well.
drwxr-xr-x+ 1 Molly Molly 364 Feb 24 11:30 Robert-Snapshot/
drwxr-x---+ 1 Molly Molly 2794 Feb 22 12:09 GMT-05-2026.02.17-11.30.00/
drwxr-x---+ 1 Molly Molly 2794 Feb 22 12:09 GMT-05-2026.02.18-11.30.00/
drwxr-x---+ 1 Molly Molly 2794 Feb 22 12:09 GMT-05-2026.02.19-11.30.00/
drwxr-x---+ 1 Molly Molly 2806 Feb 20 11:30 GMT-05-2026.02.20-11.30.00/
drwxr-x---+ 1 Molly Molly 2806 Feb 21 11:30 GMT-05-2026.02.21-11.30.00/
drwxr-x---+ 1 Molly Molly 2806 Feb 22 11:30 GMT-05-2026.02.22-11.30.00/
drwxr-x---+ 1 Molly Molly 2806 Feb 24 11:30 GMT-05-2026.02.24-11.30.00/
Stat of
File: GMT-05-2026.02.17-11.30.00/
Size: 2794 Blocks: 0 IO Block: 4096 directory
Device: 38h/56d Inode: 816486 Links: 1
Access: (0750/drwxr-x---) Uid: ( 0/ Molly) Gid: ( 0/ Molly)
Access: 2026-02-17 13:15:06.708380728 -0500
Modify: 2026-02-22 12:09:10.885165661 -0500
Change: 2026-02-22 12:09:10.885165661 -0500
Birth: 2026-02-17 13:15:06.708380728 -0500
I think it's the external security or at least the next thing to try. I'm waiting for the resync to finish (another matter)
I also don't have a problem just scripting the rync manually with the mirror (I think) option to just make the target directory mirror the source.
D4-320 & D4-SSD
Return to “File Services”
