I will not mention the docker I installed because caused a lot of misunderstanding between Redditors, the problem is:
When I access, let's say a share, on a volume on mechanical disks, and this are in stand by, there is a lag between the access and gaining real access to data, you can clearly hear disks spin up and heads released, would HyperCache help with it?
Thanks.
Would HyperCache help to mitigate lag while HDD spins up?
TerraMaster F2-425+ TOS7.latest : 1 x SN7100 1TB (System) + 2 x IronWolf 4TB (Data) + 1 x ARES 512GB (HC)
Re: Would HyperCache help to mitigate lag while HDD spins up?
You just did!
there always will be, while the hdd spin upWhen I access, let's say a share, on a volume on mechanical disks, and this are in stand by, there is a lag between the access and gaining real access to data,
would HyperCache help with it?I doubt it, unless the data is already in cache. That's tenuous.
It cannot shorten the physical power-on and self-test time of the hard drive.
However, HyperCache can significantly reduce "access latency after hard drive startup," making system/service startup faster and smoother.
The best implementation on the device to reduce startup latency is as follows:
1. Add an SSD as HyperCache (recommended: 512GB-1TB)
2. Select read-only caching mode to balance security and startup speed;
3. Place the system, Docker, and application directories in the cached storage pool.
4. Use a UPS to avoid data loss during power outages when reading or writing to the cache.
My fault, I meant "container" instead of Docker
Will take a 256/512GB nvme and try...
