Good day,
I have the problem with /tmp folder filling up all the time. Any suggestions how can I find out, what is constantly filling it, so I can prevent it from doing that? I'm running the latest TOS6 version.
Thanks in advance!
[Help] /tmp filling all the time [SOLVED]
Re: [Help] /tmp filling all the time [SOLVED]
Hello! Thank you for contacting TerraMaster. You can log in to the device terminal and execute the command du -sh ./* to check the space usage of all files and directories in the current path, and quickly locate large files/folders.
Apparentlky, the Prolwarr app in the tmnascommunity.eu is an older version and tries to update and makes back-ups and temporary files all the time, switched to Docker and for now all is fine. Thanks you.
