Google takeout and metadata problem  [Accepted]
neomesjasz
Poland
Post by neomesjasz »
Hello, I am newbie here and with Nas also.
I have problem, got my NAS f4 425 plus and 2x 8tb drives, I downloaded 3.5 tb of photos from Google takeout by cloudsync.
Problem is about metadata (tags, location time etc)
It's written in separate folder I want to connect photos again with metadata. I was trying to use immichgo add-on but it says command doesn't exist, I am completely noobie with linux and TOS. Is any other method to do it? Thx. Files are already on NAS.
Re: Google takeout and metadata problem
Are you referring to the issue of media files and metadata being separated when downloaded via Google Takeout? The metadata is stored in some JSON files. There are no related tools in TOS, but you can use third-party tools to address this issue, such as Metadata Fixer.
neomesjasz
Poland
Yes I do mean exactly that problem, but another problem is metadata fixer is for windows and I do not own windows pc
You can also consider referring to the GitHub tutorial to install the immich-go tool yourself.
https://github.com/simulot/immich-go/bl ... llation.md
neomesjasz
Poland
It's too complicated for me, just rented windows laptop and hope so metadata fixer will help
Thank you for your help
Return to “Others”
