[Help] How to enable ipvlan for Docker?
Discussion about Docker
ijurisic
Croatia
Post by ijurisic »
I create my network "my-ipvlan":
docker network create -d ipvlan --subnet=192.168.11.0/24 --gateway=192.168.11.1  \
--ip-range 192.168.11.192/26 -o parent=bond0 -o ipvlan_mode=l2 my-ipvlan
and when try to start containers i got error:
Error response from daemon: failed to create the ipvlan port: operation not supported
When I check kernel loaded mods I don't see ipvlan:
modprobe ipvlan
modprobe: FATAL: Module ipvlan not found in directory /lib/modules/6.1.120+
I have F6-424 Max, with TOS: 6.0.794-1234
Please help!
F6-424 MAX TOS6.0.750 - 4x4TB SSD (User data), 2x4TB NVME (iSCSI data), 2x8TB HDD (Surveillance)
Re: [Help] How to enable ipvlan for Docker?
The TOS6 system kernel does not include this module by default. If you really need it, you can consider installing it yourself, but please be aware of potential conflicts that may arise as a result.
ijurisic
Croatia
Post by ijurisic »
TMzethar wrote: 23 Jan 2026, 14:49 The TOS6 system kernel does not include this module by default. If you really need it, you can consider installing it yourself, but please be aware of potential conflicts that may arise as a result.
Whay not? ipvlan is core feature of any docker.
Any tutorial how to install on F6-424 Max?
Perhaps you could consider using macvlan.
ijurisic
Croatia
Post by ijurisic »
TMzethar wrote: 23 Jan 2026, 15:46 Perhaps you could consider using macvlan.
My network have problem when use macvlan (same port and diferent mac address), that is not option, valid solution is ipvlan.
Perhaps you could consider waiting for the subsequent TOS7 update, as its system kernel includes ipvlan.
ijurisic
Croatia
Post by ijurisic »
TMzethar wrote: 23 Jan 2026, 21:03 Perhaps you could consider waiting for the subsequent TOS7 update, as its system kernel includes ipvlan.
I have no other option but to wait, thanks for the information.
Do you know the release date for TOS7?
ColaChen
Post by ColaChen »
Please refer to the official update information for the latest version of our forum.
ijurisic
Croatia
Post by ijurisic »
ColaChen wrote: 24 Jan 2026, 09:12 Please refer to the official update information for the latest version of our forum.
No information about release date on forum News & Announcements
ColaChen
Post by ColaChen »
You can currently follow our weekly TOS 7 update releases here.
viewforum.php?f=28
Return to “Docker”
