F2-212: No version of qBittorrent will install
Good evening, could you tell me which version to download and how to install it? No version installs on the F2-212 server, and it says "Invalid file type" and installation is not possible. I've tried versions 4.4.5.0, 4.5.0.0, 4.5.1.0, 5.1.0.0, and 5.1.2.0.
Re: F2-212: No version of qBittorrent will install
What is the current system version running on your F2-212? Please confirm that the installation package you are using is an ARM architecture-compatible TPK file.
Version 5.1.73-00078. I'm trying to install files with the .tpk extension. I've tried versions x86_64.tpk and aarch64.tpk.
- crisisacting
- Silver Member
Where can I download the beta version of TOS 6?
- crisisacting
- Silver Member
