TOS 7.0.0375 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @Gremlin,@rfbjr, @Lex, @brianj2k, @jpeckinp, @Seton, @samius, @OttO1916 and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where accessing TOS via HTTPS would cause the update system to display an "Operation failed" error.
2. Fixed an issue where clicking the confirm button when editing a volume without modifying the storage quota configuration would trigger an abnormal pop-up window.
3. Fixed an issue where removing two member disks from the same group in a RAID10 array might not trigger the buzzer alarm or display any notification message.
4. Fixed an issue where resetting the system configuration after creating a bond would cause OVS to fail to return to the default disabled state.
5. Fixed an issue where the language loading on the File Manage page would be abnormal under slow network conditions.
6. Fixed an issue where the File Manage desktop application icon did not match the desktop icon.
7. Fixed an issue where permissions could not be properly edited when an LDAP domain user had the same name as a system user.
8. Fixed an issue where incorrect information was displayed when editing shared folders on a paginated interface.
9. Fixed other known issues.
What is new:
1. Added support for mounting remote folders via 115, Aliyun Drive, and S3 protocol.
2. Optimized the text display effect on the resource dashboard.
3. Optimized the template information when importing users.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.506 for Windows OS.
2. Download TNAS PC 5.2.506 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.506 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
Note:
Update Notes
Bugs fixed:
What is new:
Update Procedure:
Client Downloads:
Re: TOS 7.0.0375 Beta (X86) is Released for Update
Installed without a hitch, thank you for the update. (F4-425 Plus)
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
Installed on F2-221- no apparent issues
Installed on F2-424 - "Oh dear!"
Red error message at desktop something to effect "Disk Capacity check FAILED".
in Dmesg
Many repeats!
AND
Will try a reboot .......
While errors noted are still apparent in Dmesg, the re-boot was ok and no desktop error messages appeared.
in Dmesg
27.698753] systemd-gpt-auto-generator[3204]: EFI loader partition unknown, exiting.
[ 27.698759] systemd-gpt-auto-generator[3204]: (The boot loader did not set EFI variable LoaderDevicePartUUID.)AND
[ 15.715825] r8169 0000:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[color=#FF0000][ 15.717024] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20240827/psargs-332)
[ 15.717564] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 15.732685] ACPI Error:
[ 15.733156] r8169 0000:02:00.0 eth1: RTL8125B, 6c:bf:b5:03:7f:fe, XID 641, IRQ 142
[ 15.733805] r8169 0000:02:00.0 eth1: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 15.734202] Aborting method \_SB.PC00.XHCI.RHUB.HS02._UPC due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[ 15.735026] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20240827/psargs-332)
[ 15.735773] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20240827/psparse-529)While errors noted are still apparent in Dmesg, the re-boot was ok and no desktop error messages appeared.
Just for information, the following appear in update logs for BOTH systems updated contain:
This has been noted previously iirc, but it 'looks bad' - if it's not relevant maybe suppress irrelevant error messages?
<31>Jan 13 08:43:14 install[807705]: >>>>>>>>>>tos7 update kernel<<<<<<<<<
<31>Jan 13 08:43:14 install[807705]: Current system architecture: !BADKEY=x86_64
<31>Jan 13 08:43:14 install[807705]: Block device sda=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sda1=Is boot partition: !BADKEY=true
<31>Jan 13 08:43:14 install[807705]: Block device sda2=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sda3=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sda4=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sdb=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sdb1=Is boot partition: !BADKEY=true
<31>Jan 13 08:43:14 install[807705]: Block device sdb2=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sdb3=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device sdb4=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device md9=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device md8=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device md0=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device md1=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device dm-0=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:14 install[807705]: Block device dm-1=Is boot partition: !BADKEY=false
<31>Jan 13 08:43:21 install[807705]: Failed to umount block device: !BADKEY=no such file or directoryF5-221 TOS7.0.1163 - 4x4TB (Ironwolf) Traid
Thank you for your feedback, we will study the log you provided. if we need further info please help.
First machine I updated (f4-223), update process does display the reboot screen please wait and it does come back after the 5 min ish. No more update failed but it really did update. If you logon too soon and go to the Storage Manager, nothing displays for a few minutes.
Second machine updated (F4-425 Plus), again update process and reboot screen are working.
This time I waited 10min before logging on and then went to Storage Manager and everything displayed normal at first launch.
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
D4-320
F4-424 Pro updated without an issue.
Found a typo in App Center in Jellyseerr description, looks like it from another software:
F4-424 Pro
Please go to Control Panel - Service and Process, sort by CPU/RAM/Disk IO/Network, and check the processes with high usage.
I cant do that, the result is the error message you see in the screenshot.
Any attempt for any action does that.
Pete
Pete
