Hi all,
what exactly to do in case I have backed up some files to OneDrive using CloudSync (password encrypted, one-directional backup) and would need to restore them back to my local system or NAS?
Downloading backup files that haven't been password encrypted is no problem - but what exactly to do in case the files have been password encrypted (using the one-directional backup option earlier)? What functionality to use at CloudSync? I was not able to find any button or option restoring my files.
Anything I missed?
Thanks for your help!
Markus
[Help] CloudSync - Restoring password encrypted files
Re: [Help] CloudSync - Restoring password encrypted files
Hello! Thank you for contacting TerraMaster.Markus wrote: ↑11 Jan 2026, 00:44 Hi all,
Anything I missed?
Markus
When creating a task in CloudSync, simply select the "Download Remote Files Only" option and tick the first option.
Thanks for your help - seriously - I would recommend adding a separate button or something similar for restoring data. That would be significantly more intuitive and user-friendly.
Regards
Markus
Regards
Markus
Hello! We have fully documented your valuable feedback and forwarded it to our product team for evaluation. The product team will comprehensively assess its technical feasibility and alignment with user needs. Thank you again for your contribution to the improvement of our products!
