Gitlab application
dgarner
Gitlab application
Post by dgarner »
I would love to see Gitlab able to be installed directly from the application menu.
Re: Gitlab application
I will feed back this requirement to the product team for evaluation. Currently, you can install GitLab via Docker.
dgarner
Post by dgarner »
Any updates on this?
I know this can be done via the Docker Manager, however, I am not certain if coincidental, however, are there any benefits, resource wise? eg, are applications added into the App Store optimized for this hardware, or is this the exact same thing and RAM/CPU usage will be the same across any installation method?
Also, would like to request to add auth/iam software, such as Authentik, thank you very much.
Setting aside Docker’s own resource overhead, there is generally little difference in performance overhead between running the same version of an app in a TOS environment and in a Docker container.
If all goes well, we expect to release it in about a month.
rvescovi
Italy
Post by rvescovi »
Hi. I have installed GITLAB in docker container on a F4-424 PRO, and it works really fine, the only issue in case you use DinD manage images with docker:27.2.1 as similar to the host
