TOS 7.0.0364 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @jdubya,@athurdent,@Seton,@rfbjr,@jdcesari,@jpeckinp,@mmalchuk and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where permissions could not be properly set for some Docker containers.
2. Fixed an issue where the TOS desktop application icon did not automatically update after an application update.
3. Fixed an issue where Debug mode was turned off when updating from TOS 7 to TOS 7.
4. Modified the default port for the msgbus process in the system processes.
5. Fixed an issue where File Manager search occasionally consumed excessive memory.
6. Fixed an issue where the media indexing database service did not correctly bind to the local loopback address after enabling media indexing.
7. Fixed an issue that prevented joining a domain whose advanced settings had been cleared.
8. Fixed an issue where some page pop-up styles were not updated.
9. Fixed an issue where editing IPv6 settings occasionally required two clicks to take effect.
10. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.506 for Windows OS.
2. Download TNAS PC 5.2.506 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.506 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
JSCFORCE
Re: TOS 7.0.0364 Beta (X86) is Released for Update
Post by JSCFORCE »
Updated successfully, creating some docker apps to see how well they work. (F4-425 Plus)
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
Updated, no apparent issues. However (minor glitch), I have TFM set up using a desktop icon. When clicked, APP Centre comes up as if TFM is disabled/not installed :?: (but it was installed and enabled). Could not use the "Open" function in App Centre. Disabled TFM and then re-enabled and eventually it opened. Clam AV & Multi-media server also have desktop icons, but no issues with these. Initiated a re-boot and all OK.
storageninja
Netherlands
Post by storageninja »
Thank you for fixing the docker issues! F4 SSD confirmed working.
rfbjr
Post by rfbjr »
Starting to check out the release, hibernation options were rechecked after 364 was installed.
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
Lex
Post by Lex »
can't turn on media index.
Check box, press apply. In status write "Filed to create index"
F4-423
brianj2k
Post by brianj2k »
Unable to do the update. system complains that the download failed. also cannot update the file manager app which is now no longer working.
F6-424 | 7.0.0333 currently
here's the email i get:
"The update package download failed. Please visit the official TerraMaster download center to manually download and install the update.
Device name: TNAS
Model: F6-424
TOS version: TOS_X642.0_7.0.0333
jpeckinp
Post by jpeckinp »
UPS unrecognized again.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
Seton
Post by Seton »
Permission in Docker are working correctly. The problem with granting rights to users through settings is a shared folder - permission. Changes are not applied, and a message about unsaved changes appears when you exit the menu. There is also a problem with Jellyfin, the metadata of videos uploaded online and manually is not saved.
Lex wrote: 07 Jan 2026, 05:26 can't turn on media index.
We are unable to reproduce this issue temporarily. Please generate and download the log report in TOS > Technical Support > Issue Report, then send it to our technical support email ([email protected]). We will analyze it.
Please include the link to this post in the body of the email.
