[Help] Unable to Mount USB Paths for NFS Share on F2-425  [SOLVED]
Authenticate
Post by Authenticate »
Hello, I am trying to create an NFS share with my mounted D4-300, which is attached to my F2-425 (non-Plus). I can see that the drives are mounted on the NAS, and I want to share my media with Kodi. However, I am not seeing any option to select the USB paths in the shared folders I create — it only shows Volume1. I’m not sure what I’m doing wrong. I also checked the USB Storage Manager, but it doesn’t provide any options there either. Am i not able to share share paths with mounted USBShares?
F2-425 (Non-Plus) 2x8TB 6.0.794
Re: [Help] Unable to Mount USB Paths for NFS Share on F2-425  [SOLVED]
Not supported yet. Future TOS versions will support indexing USB content.
Authenticate
Thank you for the update
Return to “Privileges”
