Job template or import/export
rfbjr
Post by rfbjr »
I don't have that many shared folders but it would be nice to create one Shapshot or rysnc or whatever job. Export it, replicate the line and add more jobs for the different shared folders. Then import the file back in.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Re: Job template or import/export
You can download and install snapshot from the Application Center, or create an Rsync synchronization in the Backup module. If you need to run scripts automatically, you can create a scheduled task in the Control Panel.
rfbjr
Post by rfbjr »
I do use the snapshot app as well as rsync. For example I have 12 shared folders I want to take a snapshot then rsync the snapshot folder to a remote nas. I'm asking for the ability to export the current job from the snapshot/rsync app and then have the ability to modify that exported file, add more entries for the other shared folders, then import that file back into the system.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Import and export tasks are not supported for now. I will feed this requirement back to the product team for their evaluation.
