Data Scrubbing Greyed Out?
Authenticate
Post by Authenticate »
Hello, I just upgraded to the F2-425 (Non-Plus) from the older F2-221 model, and I was able to enable data scrubbing on the older unit. However, I can't enable it on the new unit. My file system is BTRFS.
F2-425 (Non-Plus) 2x8TB 6.0.794
Re: Data Scrubbing Greyed Out?
The Secure Erase and Disk Wipe functions are only applicable to disks that are not in use. For disks in a storage pool, delete the corresponding volume and storage pool first; for mounted disks, unmount them manually first. After that, you can use these functions.
