Multiple Connections Issues Map Drives
Alexh4e
Post by Alexh4e »
Hi there,
I’ve a problem with a Terramaster F2-210 in a small office with 4 pc connected. One of these pc everyday has problem to connect to mapped drive in Explorer.
I’ve mapped 2 folders with rights and permissions (all is good configured passwords etc as same as the other Pc of the office), but every day I need to do from command line "net use * /delete" command for discard credentials and reinsert..
Often do that command is not enough.. and I have to reboot the NAS. Another curious thing is that if I can try to connect to the storage in Https the page show me a pop-up with “Token exiped”. If i connect in “Chrome hidden mode” I can access with all credentials created.
Can you please help me?
Re: Multiple Connections Issues Map Drives
As for the access to the mapped drive, what’s the operation system for the specific computer? Is it the same with other 3 computers? It’s possibly not the problem with our device, but the reason of the computer system and settings there.
As for “token expired”, it will prompt you that token expired when there is no operation on TOS webpage more than 24minutes. You can refresh the page, and enter the username and password to login again.
Return to “File Services”
