TOS 7.0.0309 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @MaxBeard, @athurdent, @storageninja, @crisisacting, @T1mbo, @Pingjockey, @Trident, @emperorgr, @JSCFORCE, @Besik086, @cyberspider, @jpeckinp, @epicwomble, @ruzaj, @DCCentR, @rfbjr, @koros1691, @KikoWTI360, @abs1ck, @Lex and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where previously configured settings were not retained after disabling SNMP.
2. Fixed an issue where creating a traffic control rule could fail when a custom port range was selected.
3. Fixed an issue that could prevent access to shared pages when the share link password contained special characters.
4. Fixed an issue that could cause failures when repairing the Hyper Cache of a RAID 1 array.
5. Fixed an issue where the storage pool status displayed incorrectly when the Hyper Cache of a RAID 5 array was corrupted.
6. Fixed an issue where canceling the quota of a Btrfs volume might not save successfully.
7. Fixed an issue where the conditions for RAID 10 degradation and repair were not accurately judged.
8. Fixed an issue where guest access did not work properly on macOS.
9. Fixed an issue where mounting a cloud drive occasionally took over ten seconds to load and display properly.
10. Fixed an issue where some access permission settings were not successfully restored when restoring system configurations.
11. Fixed an issue where an incorrect prompt appeared when dragging files into a directory with restricted permissions.
12. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.506 for Windows OS.
2. Download TNAS PC 5.2.506 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.506 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
JSCFORCE
Re: TOS 7.0.0309 Beta (X86) is Released for Update
Post by JSCFORCE »
I was able to successfully update to this version. (F4-425 Plus)
My heart skipped a beat at first because on the screen it said "Failed" but it actually did update it.
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
jdcesari
French Southern Territories
Post by jdcesari »
it does not sole immich issue.
JSCFORCE
Post by JSCFORCE »
File transfer dialog is still broken. It reached 100% and there were still many files transferring.
It did finish transferring later.
JSCFORCE wrote: 23 Dec 2025, 14:08
jdcesari wrote: 23 Dec 2025, 13:52
The three issues you mentioned are still being fixed. Once resolved, they will be noted in the release notes.
jdcesari
Post by jdcesari »
thks - but i need immich.
fixing is only a matter of days, of weeks or of months ?
if you plan months, i roll back to tos6 ( but it is long job for me)
if it is days, of course ill wait
execpt this, TOS7 is so great !!
rfbjr
Post by rfbjr »
The message subscription isn't working yet? I mean we should have gotten an email about 309 being released.
Just updated the F4-223 to 309, checking it out now.
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
ruzaj
Austria
Post by ruzaj »
Dear Terramaster,
after successful update, tnas.online connection was lost.
Lex
Post by Lex »
After update all volumes is corrupted. (can`t add image)
F4-423
jdcesari wrote: 23 Dec 2025, 16:32 thks - but i need immich.
This issue is expected to be resolved in the upcoming release, which is scheduled in 2–3 weeks. You may use TOS 6 as an interim workaround.
