[Help] Plex Descriptive Audio Disable
great0dane
Post by great0dane »
I am using TOS Plex version 1.42.2.10156 to host video media on F5-422 with TOS 6.0.794. When connecting to Plex on Roku, I am unable to disable the Descriptive Audio channel from videos. The videos have 5.1 & Stereo audio channels, I have tried each one and the narration plays on every stream, ruining the video. Is this an issue with how TOS Plex app sends video to Roku or an issue with the Roku Plex app?
MikeZhang
Re: [Help] Plex Descriptive Audio Disable
Post by MikeZhang »
great0dane wrote: 21 Dec 2025, 03:55
According to Plex's official support and the experience from the user community, the key to solving this problem doesn't lie in system settings but rather in the audio track selection within the Plex app. Follow these steps, and you should be able to resolve the issue:
Select the correct audio track while playing the video (the most direct method)
This is the preferred way to solve the problem. When you are playing a video with narration:
Bring up the playback menu: On the Roku remote, press the "Down" directional key or the "OK/Select" key. The playback progress bar and settings menu will appear at the bottom of the screen.
Locate the audio settings: In the playback menu, look for and select the "Select Audio Track" option or the "Settings" button, which is usually represented by a gear icon.
Switch the audio track: In the pop-up audio track list, you should see multiple options, such as "English (AC3 5.1)", "English (AAC 2.0)", and "English (Descriptive Audio)". Choose any option other than "Descriptive Audio". The video will buffer briefly, and then the narration will stop, restoring the normal audio.
Return to “Plex Media Server”
