[Help] Is it possible to install 2.5" SSD to F8 SSD Plus
AzzGuard
Kazakhstan
Post by AzzGuard »
I wondering to know is it possible install 2.5" SSD to F8 SSD Plus, using M.2 to 2.5" adapter?
MikeZhang
Re: [Help] Is it possible to install 2.5" SSD to F8 SSD Plus
Post by MikeZhang »
AzzGuard wrote: ↑19 Dec 2025, 19:25
Sorry it's not supported, however, you can attach your SSD to F8 SSD Plus USB ports after connecting 2.5" SSD to USB adapter, it's equal to internal drives which enable you to create storage pool for it.
