[Help] files not showing after update
jwills70
Post by jwills70 »
terramaster t9-423
op 6.0.794
i had problems with my nas i could not log into it it was frozen so i had to unplug the nas
it rebooted but said disk one had a warning so i took it out and placed a new drive in but it would not start the repair so i tried a update from 6.0.5 or there abouts to the latest one and ordered another new drive and it worked it started rebuilding unfortantly now i noticed that i cant see any of my files through windows and on the nas the folder appears empty
i remember somthing about file permission but took no notice as i had already updated my other nas and everything was ok so i am not sure if this has something to do with it or not
the space is still being used and the files must still be there as i have plex on my pc and it can still play the files i just cant see them in the folder anymore
this is the folder
if i try to write to the folder i get a message saying remove the write protection or use another disk
Re: [Help] files not showing after update
Please generate and download the log report in TOS > Technical Support > Issue Report, then send it to our technical support email ([email protected]). We will analyze it. Also, include the link to this post in the body of the email.
Return to “System Update”
