VirtualBox - Updated? [SOLVED]
Hi there, the current VirtualBox (v. 7.0) is now over three years old and there have been several feature and, more importantly, security updates. When can we expect an updated version certified? Thanks!
- crisisacting
- Silver Member
Re: VirtualBox - Updated? [SOLVED]
The PHP VirtualBox project itself has only been updated this year after years of stagnation.
In place updates to the current build is likely not in the cards as
TOS 7 has moved onto a newer virtualization solution & updates to TOS 6.× builds are mostly going to dwindle down.
Ah OK! As long as I can use the new solution for my MSWin VMs, that will be great!
The valuable feedback from all users is very important for us to continuously improve our products and services. VirtualBox has been republished in the TOS 7 App Center. Thanks for your support of TerraMaster!
