[Help] TOS7 Beta install failed on my F5-221  [SOLVED]
ChadH42
Post by ChadH42 »
After reading all of the notes regarding the installation of TOS7, I performed the update. After 10 minutes of waiting and the NAS not being found on my network, I tried the "Method B" reinstall from the forum notes for reinstallation. The NAS is still not visible on my network.
What can I do the get it back??
Re: [Help] TOS7 Beta install failed on my F5-221
viewtopic.php?p=53550#p53550
The installation of the new TOS 7 Beta requires manually uploading the corresponding new Bootloader file on the initialization page. When you initially obtained the TOS 7 installer via email, did you also receive the corresponding new Bootloader? We have sent the new Bootloader to you via forum private message. Please try again.
In addition, please confirm again whether you are using the TOS6-specific USB initboot boot system.(Legacy for F5-221)
viewtopic.php?t=6433
Hemps
South Africa
Post by Hemps »
I received the TOS7 installer but no Bootloader, can someone message me the TOS7 Bootloader please?
Model F4-425 Plus
Regards
Hemps wrote: ↑22 Jan 2026, 18:46 I received the TOS7 installer but no Bootloader, can someone message me the TOS7 Bootloader please?
I have sent it to you via private message. Please check.
ChadH42
Post by ChadH42 »
TMzethar wrote: ↑22 Jan 2026, 19:50
I used the files you provided but it didn't change the outcome, still won't boot.
ChadH42 wrote: ↑19 Feb 2026, 02:57
Could you let us know the specific situation at the moment? It is recommended that you provide screenshots to show it.
ChadH42
Re: [Help] TOS7 Beta install failed on my F5-221  [SOLVED]
Post by ChadH42 »
TMzethar wrote: ↑26 Feb 2026, 09:56
Thank you but I have solved the problem. I removed the internal USB drive and the NAS booted up TOS7 without issue.
Return to “Initialization”
