[Help] Impossible to upgrade because Volume1 doesn't exist
lestatminiyo
Spain
Post by lestatminiyo »
I recently removed my Volume1.
Since that moment, I'm receiving alerts because the system is trying to download upgrades in this unexistent volume.
Regards
¡Error al actualizar! Su volumen no tiene suficiente espacio libre restante para realizar una actualización del sistema. Asegúrese de que el espacio libre del Volumen 1 (o el primer volumen) no sea inferior a 3 GB.
Device name: NAS
Model: F4-424 Max
TOS version: TOS_X642.0_6.0.783
TNAS System Notification
https://www.terra-master.com/support/
Re: [Help] Impossible to upgrade because Volume1 doesn't exist
Volume 1 is typically used as a dependency directory for some system functions. When updating the system, update packages are temporarily placed in the directory under Volume 1. If your Volume 1 does not exist, you can temporarily create Volume 1 using any available drive to complete the system update.
If you currently have Volume 2 or other volumes, you can also try restarting the NAS to make Volume 2 automatically become the system-dependent volume.
Return to “System Update”
