Git server and PATH issues  [Accepted]
Maniform
Post by Maniform »
Hello team,
I tried to setup a git server on my F4-424. To get the git features, I installed ModBase1 (https://tmnascommunity.eu/download/modbase1/) from the community. Git setup is correct and the PATH is setted.
What I did :
  • Create a shared folder called "git" in Volume1
  • In git, create a project folder "test.git"
  • In this folder, I ran the command
    git init --bare
  • On my PC, I tried to clone with
    git clone ssh://[email protected]:9222/Volume1/git/test.git
    it ask me for my password then returns error
    bash: line 1: git-upload-pack: command not found
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
From what I found, it seems to be an issue with the PATH. When I log in with SSH, git-upload-pack is available without any further configuration (PATH is right) but through a git command, the PATH is not setted the same way so some git features are not available.
Some workarounds require to edit ssh config from the NAS, but TOS seems to ignore .ssh folder or any .profile/.bashrc configurations.
The only working way I found for now is to use a Raspberry Pi as a git server. I mounted /Volume1/git to my Pi then I use
git clone ss://user@raspberrypi/mnt/git/test.git
and it works perfectly.
Any solution to make a git server on TOS 6 ?
[System Informations]
  • Model: F4-424
  • Version: TOS 6.0.794-01324
  • ModBase1 version: 1.00.22
Re: Git server and PATH issues
It may be a permission issue. Could you please confirm if you are using the superuser on the TNAS system? Only the superuser has the permission to access via SSH.
Maniform
Post by Maniform »
I use my account that is administrator.
I see there's a "super" folder in homes so maybe there's a "super" user hidden somewhere. I tried it but I don't have the password and I can't find it anywhere in the documentation.
Just to clarify, I tried my admin password on super account but it's not working.
Perhaps you can learn about relevant information here.
viewtopic.php?t=1476&hilit=ModBase1
Maniform
Post by Maniform »
Maybe I'm missing something but I can't find any way to make it work through ssh without customizing the system.
I'm investigation a way using docker to make it work natively.
Maniform
Re: Git server and PATH issues  [Accepted]
Post by Maniform »
FIXED !!! I found a way with no big modifications and it's working !
I was able to see the content of PATH through ssh commands with
ssh -t <user>@<tnas> -p <port> 'echo $PATH'
Logging with ssh and showing PATH doesn't give same result.
The PATH contains
/usr/local/bin
but by default, there's no such dir. I created it and created symbolic links to every git command.
mkdir /usr/local/bin
ln -s /usr/local/ModBase1/sys/bin/git /usr/local/bin/git
[Repeat for every git binary]
Now git server works !
Just so you know, I first created a symbolic link of full ModBase1's bin folder. It works too but it shows following issues everytime you log in with ssh after that. I guess it causes conflicts with other existing binaries.
dirname: missing operand
Try 'dirname --help' for more information.
Return to “Others”
