[Help] can't access encrypted shared folder on win11
Fluter28
Australia
Post by Fluter28 »
Hi all
I can't access my encrypted folder via win11 network drive map. It doesn't accept my password.
Non encrypted folders work. Any help please?
Re: [Help] can't access encrypted shared folder on win11
First, you need to log in to TOS with a browser to check whether the encrypted shared folder has been successfully mounted and whether it can be viewed normally in the TOS file manage.
If you have restarted TNAS, you need to remount the encrypted shared folder before you can access it normally.
Fluter28
Australia
Post by Fluter28 »
Hi there,
Thanks. The folder is definitely mounted , I found out you have to activate guest access, then I can map the drive and access it , otherwise it won't work. If I disable guest access and unmount the folder, and mount back , I can't access it again ...
TMbuddy
Post by TMbuddy »
Fluter28 wrote: ↑15 Nov 2025, 22:55
Normally, the shared folder should be accessible via SMB immediately after mounting. I have escalated your issue to our internal team for investigation. Please allow us some time to verify and address the problem.
Return to “File Services”
