D4-320: Fan always on
olli
Germany
Post by olli »
I have an D4-320 which is connected to an ASUS-NUC-15 running Linux via USB-C. If the hard disks are not accessed by the OS, they spin down after approximately 5 minutes. However, the fan stays always on, even if I wait hours, which is somewhat annoying. Is that the expected behavior? Interestingly, the fan turns off immediately if I disconnect the USB cable.
Re: D4-320: Fan always on
The USB ports of mini computers often suffer from weak signal issues. Please use an active HUB for connection.
In addition to connecting through a HUB, you can also try using shorter USB-C cables, such as 30cm or 0.5m, which can also reduce signal attenuation.
olli
Germany
Post by olli »
I am not convinced that a weak signal from USB-Ports is the root cause for the fan not turning off. I did extensive tests with the hard drives and I saw no reconnects or other problems that were observed by other users during transfer of morethan 8 TB of Data. However, I will try to connect the D4-320 to a different compute and see if the problem with the fan depends on the computer. Unfortunately, I don't have an external powered USB hub available right now.
D4-320 is equipped with an intelligent temperature-controlled fan. The fan speed adjusts according to the temperature, but it will not stop rotating due to low temperature. When the operating system issues a command to put the HDD into sleep mode, the fan will stop rotating until the HDD is read/written again. When using any SSD, the fan may not stop as SSDs themselves do not require sleep mode, and the SSD's own controller also needs heat dissipation.
Return to “USB Series”
