[Help] D5-300 Problem with Seagate NAS drives not initialising  [SOLVED]
GOODCHAPJOSH
Ireland
Post by GOODCHAPJOSH »
I am having an issue with my Terrasmaster D5-300 and a Seagate ST4000VN006-3CW104 4tb Ironwolf drive. I have ran analysis on the drives and they are healthy but they will not initialise on startup. I did some troubleshooting online and people seem to point to the fact that the Seagate drives have a PUIS feature which means the software doesnt immediately recognise them. Is there any software update that could help with so the drives boot up normally. I am using a mac mini to access the terramaster.
TMjack
Re: [Help] D5-300 Problem with Seagate NAS drives not initialising
Post by TMjack »
Hello, the screenshot shows that two hard disks in the D5-300's RAID5 array have abnormal status, causing the MAC computer to fail reading data. Please try shutting down the device, then reinstall all hard disks in the correct order, and check if the array can recover.
GOODCHAPJOSH
Ireland
Thanks for your response TMjack, unfortunately this does not fix the problem. is there any merit to this theory? and any solution based on that? or any other idea on how to get Softraid to recognise them as they are healthy?
TMjack
Post by TMjack »
If your hard drive has the PUIS (Power-Up in Standby) feature enabled, the D5-300 device may fail to fully recognize the drive during power-on. In this case, you need to use the official Seagate-provided tool (such as SeaChest Utilities) to disable the hard drive's PUIS feature in order to restore its normal functionality. If the issue persists, replacing the hard drive may be the only recourse.
Our D5-300 itself supports the hard disk smart sleep function, so there is no need to enable the PUIS (Power-up in Standby) function again.
GOODCHAPJOSH
Ireland
is there firmware for the terramaster d5-300? I cannot find it anywhere
The previous reply was an automatic response from an advertising robot. There is no universal firmware update for the D5-300. Are you experiencing the same issue as before? Have you tried disabling the PUIS function?
Return to “USB Series”
