Web interface certificate
AES
Post by AES »
I only have a single certificate installed for the terra-master.com web interface. It's also installed for https.
Why does the browser see the *.tnas.link certificate if it's long gone from the web interface, and a different certificate is assigned to https, and the device has rebooted?
The internet tells me I have to go to the command line to change it?! https://qna.habr.com/q/1399276
Then why do I need a web interface and direct configuration there?
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: Web interface certificate
Hi.
In addition to general HTTPS access, TNAS.online's HTTPS access also needs to be implemented simultaneously, which may make the certificate configuration somewhat complex. The default terra-master.com for HTTPS is not effective. Once you modify it to your own valid certificate, accessing via WAN or LAN will use your own certificate.
