[Help] Moving from F2-421 to F2-425
TerraSync is a cloud drive service application that helps users build their own private cloud drive services with their TNAS devices.
CapCaveman
Panama
Post by CapCaveman »
Hi, I plan to move soon from my 5 year old (and working) F2-421 (latest TOS 4 firmware) to a new F2-425.
What is the best way to move all my files from the old disks to the new disks? I don't plan on using the old disks, since they are 5 years old. Better to use new ones.
Which is the recommended app to use? Rsync? Terrasync?
Thanks.
TMnight
Re: [Help] Moving from F2-421 to F2-425
Post by TMnight »
TOS4 does not support Terrasync, so it is recommended to use Rsync or Duple Back for data backup.
CapCaveman
Panama
Thanks! Will try it out.
Return to “TerraSync”
