[Help] Home Assistant keeps crashing with the error "Buffer I/O error on device sda" in VirtualBox
nomadfromx
Kazakhstan
Post by nomadfromx »
I installed a new virtual machine with Home Assistant from scratch (by importing an .ova file) in TOS6. After that, I restored a backup of my HA version. Now, once or twice a day, this version of the virtual machine crashes with a "Buffer I/O error on device sda" error. After restarting, it works for a while (several hours), and then crashes again with the same error.
What could be causing this, and how can I fix it?
I also installed the same version of HA a year ago on the same version F6-424 MAX, and I didn't get any such errors.
nomadfromx
Kazakhstan
Re: [Help] Home Assistant keeps crashing with the error "Buffer I/O error on device sda" in VirtualBox
Image uploads to the forum aren't working. Here are the error logs:
ha >
[32311.892387] sd 0:0:0:0: rejecting I/O to offline device
[32311.892650] I/O error, dev sda, sector 251272096 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.892877] Buffer I/O error on device sda8, logical block 2968080
[32311.893037] I/O error, dev sda, sector 251272120 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.893254] Buffer I/O error on device sda8, logical block 2968083
[32311.893409] I/O error, dev sda, sector 251274232 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.893659] Buffer I/O error on device sda8, logical block 2968122
[32311.893899] I/O error, dev sda, sector 251255044 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.894122] Buffer I/O error on device sda8, logical block 2968131
[32311.894294] I/O error, dev sda, sector 251276116 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.894511] Buffer I/O error on device sda8, logical block 2968145
[32311.894668] I/O error, dev sda, sector 251277192 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.894879] Buffer I/O error on device sda8, logical block 2968157
[32311.895029] I/O error, dev sda, sector 253346448 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.895255] Buffer I/O error on device sda8, logical block 2986624
[32311.895407] I/O error, dev sda, sector 253366000 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.895627] Buffer I/O error on device sda8, logical block 2986843
[32311.895776] I/O error, dev sda, sector 253367520 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.895988] Buffer I/O error on device sda8, logical block 2988662
[32311.896137] I/O error, dev sda, sector 253369004 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[32311.896348] Buffer I/O error on device sda8, logical block 2988681
[32311.896800] Buffer I/O error on dev sda7, logical block 293, lost async page write
[32311.897500] Aborting journal on device sda8-8.
[32311.897795] EXT4-fs error (device sda8): ext4_reserve_inode_write:5862: Journal has aborted
[32311.898273] EXT4-fs error (device sda8): ext4_dirty_inode:6066: inode #394948: comm node: mark_inode_dirty error
[32311.898407] EXT4-fs error (device sda8): ext4_journal_check_start:84: comm systemd-journal: Detected aborted journal
[32311.898450] EXT4-fs error (device sda8) in ext4_dirty_inode:6067: Journal has aborted
[32359.806503] Aborting journal on device sda7-8.
[32360.172491] scsi target0:0:0:0: mptspi: ioc0: mpt_config failed
[32428.694183] scsi target0:0:0:0: mptspi: ioc0: mpt_config failed
[32427.860997] scsi target0:0:0:0: Domain Validation Initial Inquiry Failed
[32428.055051] scsi target0:0:0:0: mptspi: ioc0: mpt_config failed
[32428.074134] scsi target0:0:0:0: mptspi: ioc0: mpt_config failed
[32428.046095] EXT4-fs error (device sda7): ext4_reserve_inode_write:5862: IO failure
[32428.047921] EXT4-fs error (device sda7): ext4_dirty_inode:6066: inode #43: comm systemd-timesyn: mark_inode_dirty error
[32428.048509] EXT4-fs error (device sda7): ext4_dirty_inode:6067: IO failure
[32428.051291] EXT4-fs (sda8): Remounting filesystem read-only
[32432.989185] systemd-coredump[2295]: Process 105 (systemd-journal) of user 0 terminated abnormally without generating a coredump.
[32448.986325] EXT4-fs error (device sda7): ext4_journal_check_start:84: comm systemd-timesyn: Detected aborted journal
[32448.986455] EXT4-fs (sda7): Remounting filesystem read-only
nomadfromx
Kazakhstan
This bug is associated with a bug in the operation of the btrfs system. The decision was made here - viewtopic.php?t=9215
This is possible. The load of BTRFS quota (btrfs-transact + btrfs-cleaner) may be very high, which could cause abnormal operation of the program from the day before yesterday. It is not recommended to run important programs while BTRFS quota is running.
Return to “Virtual Machines”
