[Help] Compatibility 32GB RAM for F2-424  [SOLVED]
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Ziptr
Spain
Post by Ziptr »
First of all, I apologize for my poor English. I’m from Spain.
I wanted to ask how it’s possible that my F2-424 works perfectly with an Integral 16GB 4800MHz RAM (shown at the top of the attached image), but does not work with an Integral 32GB 4800MHz RAM (shown at the bottom of the image). They appear to be very similar, so I’m wondering if they should be compatible because they are from the same brand — or if that’s not necessarily the case and the new RAM might actually be incompatible and need to be replaced.
Thank you in advance.
Best regards.
F2-424 2TB (7.0.1422)
F2-210 500GB (Stopped)
D1 SSD Plus 1TB
Re: [Help] Compatibility 32GB RAM for F2-424
I would be suspicious that the 32GB sodimm is actually counterfeit. The chip speed is printed as 4800MHz whereas comparable ram on Amazon UK is stated as 4800MT/s (as is your 16GB sodimm).
In DDR memory MHz and MT/s are not the same thing.
Frustrated Beta Tester!!!
Ziptr
Spain
Post by Ziptr »
Hello Gremlin,
Thank you for your answer. In reality I do not think that is the reason since physically the memory has blocks of memory on both sides, which would correspond with a larger memory, but in any case I have proceeded to return it and ask for the one offered by Terramaster’s own store despite being much more expensive. I’m not supposed to have a problem with her.
I will report as soon as I get it and can test it.
A greeting.
D1 SSD Plus 1TB
shou
Singapore
Post by shou »
Hey, man, I think you can try to re-insert your ram a couple of times, shaking the RAM as you insert it, and waiting 4 minutes at a time. If you can't hear the buzzer, rub your gold finger with an eraser and try again The last way to try, deduct the CMOS battery, rest for 1 minute, then install the CMOS, try to insert the memory,
Ziptr
Spain
Post by Ziptr »
Hello shou,
I tried to reinstall it several times, waiting up to 20 minutes and nothing. What to clean the contacts with eraser also despite being a new memory with completely shiny contacts (that technique usually works on very used, worn, stained...) and no success, so I have directly returned it and ordered the "official" of Terramaster. As I said in my previous message, I will report how the new memory has worked.
In any case, thank you very much for your answer.
A greeting.
D1 SSD Plus 1TB
TMjack
Post by TMjack »
Hello! To address the memory compatibility issue, you can try the following steps to improve compatibility with the other memory module: Enter the BIOS setup interface, navigate to Chipset > Memory Configuration, and then change the SA GV option to Disabled.
However, to ensure system stability, we still recommend that you prioritize using memory modules listed in the official compatibility list.
Ziptr
Spain
Post by Ziptr »
Hello Jack,
How do I access the BIOS settings of the NAS? I would like to check this option if possible while still having the memory here, but I do not know how that process would be done.
Thank you.
A greeting.
D1 SSD Plus 1TB
Re: [Help] Compatibility 32GB RAM for F2-424  [SOLVED]
Hello, you can connect the NAS to a monitor and keyboard. Press the Del key on the keyboard during startup to enter the BIOS.
Ziptr
Spain
Post by Ziptr »
Hello CursaYang,
Thank you for the answer, I did not know that we could access the BIOS and make the changes that your colleague told me. It is already late because I need to extend when before and I have ordered the memory recommended by the manufacturer, but it is interesting to know for the future.
A greeting.
D1 SSD Plus 1TB
sianderson
Post by sianderson »
as i was curious about this i came across the fact that it is up to 32gb
is there a second RAM slot and you are trying to put 32gb + original 8gb = 40gb
or are you replacing the only ram chip in the unit to give you a total of 32gb?
it would work with a 16gb chip because 16 + 8 = 24gb so under the 32gb limit if i am reading the specs correctly that there is an upper limit of 32gb on the unit
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Return to “Compatibility”
