[Help] Cloudsync does not work with Google Photos  [SOLVED]
davidgar
Mexico
Post by davidgar »
I bought Terramaster TNAS, almost exclusivelly for this porpuse,
now that I have I find out there is no way to sync my google photos to my NAS
could you help me do it, or maybe tell me how to do?
thanks
David
Re: [Help] Cloudsync does not work with Google Photos
Synchronization of Google Photos content is not supported at the moment. We will submit this as a requirement to the project team.
davidgar
Mexico
Post by davidgar »
TMzethar,
thanks for the response, but is there a time line to implement this?
as mentioned before this synching was the main reason for me to buy unit
or is there a way to sinc with the pics. on my phone? (android)
appreciate the support
If your photos are stored on your mobile phone, you can sync them to your NAS using TNAS mobile app.
wagans
Re: [Help] Cloudsync does not work with Google Photos  [SOLVED]
Post by wagans »
Having the same issue. I can offer you a rather clunky interim solution that I am currently using.
1. Use Cloudsync to sync files from your NAS to Google Drive.
2. Use a service like Multicloud. (https://www.multcloud.com) to sync from Google Drive to Google Photos. A lot of these providers have Black Friday deals this time off year.
The big downside is that you end up doubling you Google storage usage. Once the files sync from Google Drive to Google Photos you have two copies. If you delete them from Google Drive, they get readded by Cloudsync on its next run.
If anyone has a better solution or a way to prevent the duplicates in Google storage, I would appreciate comments.
A direct path would be much more efficient!!!
Return to “CloudSync”
