Add SSD and migrate TOS from HDD  [SOLVED]
ajkaramba
Germany
Post by ajkaramba »
I would like to add an SSD to my F4-423 and install TOS on it. At the moment, my system is running with 4 HDDs, and TOS is currently installed on them.
My goal is to migrate TOS to the new SSD without losing any of the data stored on the HDDs. The advantage would be that the HDDs could go into standby more often, while the SSD handles the system operations.
Is this migration possible, and if so, what would be the correct procedure?
Thank you in advance for your help!
TMjack
Re: Add SSD and migrate TOS from HDD
Post by TMjack »
Hello, starting from TOS version 6.0.750 and subsequent versions, the system has introduced a system disk migration feature. With this feature, you can migrate the system from an HDD to an SSD. For specific steps, please refer to the detailed instructions in the TOS 6 help documentation. Additionally, please ensure that your TOS system version is TOS 6.0.750 or later.
TMEmily
Re: Add SSD and migrate TOS from HDD  [SOLVED]
Post by TMEmily »
ajkaramba wrote: ↑05 Oct 2025, 00:18 Hello,
Hello!
Thank you for your interest. Our latest TOS 6.0.783 system now officially supports system disk migration functionality.
You can directly access this feature through the following path:
Control Panel > Disk > System Disk > Migrate
Within this interface, simply select your new SSD as the target disk to complete the system migration effortlessly. This feature is designed to help you seamlessly transfer your system to a higher-performance drive, thereby enhancing system responsiveness and optimizing storage efficiency.
If you have any questions during the operation, please feel free to consult us.
ajkaramba
Germany
Post by ajkaramba »
That worked, thanks!
Is it also possible to move installed Apps (Jellyfin, Docker Engine and Docker Manager) to the new SSD?
With SSH I can see that it is still installed under Volume1:
ls -lah /usr/local/jellyfin
/usr/local/jellyfin -> /Volume1/@apps/jellyfin
ajkaramba wrote: ↑08 Oct 2025, 19:25 That worked, thanks!
Currently, only the system disk is supported for migration, and installed applications cannot be migrated directly. You can choose a new SSD when installing applications.
jemlinus
Post by jemlinus »
Sorry to hijack but after I migrated, I still have two HDD showing in the system disk. Do I delete those two HDD from the section?
