[Discussion] F4-212 - Is it advisable to upgrade from TOS5 to TOS6?
fulvion75
Italy
Post by fulvion75 »
due to a issue, i had to reinstall TOS5.1.73 on my TNAS. It's a pretty new and clean installation and i was considering to upgrade to TOS6 before doing all the additional configurations i need. I was wondering if my use case would have any benefit from this upgrade as, i think, i make a simple use of my NAS.
I only use the DLNA server and TerraPhoto apps plus SMB sharing, SSH and rsync. But i also had to make some basic changes at OS file level to allow:
  • The pfSense box to update the SSL certificate via SSH with only public key auth
    Configure NUT to monitor a remote UPS (connected to the pfSense box) and shutdown the NAS after 5 minutes on battery
    Create firewall rules i wasn't able to create via the web interface (i'd like to be more specific but, honestly, can't remember how the GUI was preventing me to do it. I only remember i had to manually edit the config file the GUI uses, to add some of the rules i needed)
    Make NAS work with specific clients from a different subnet (limited to the mentioned apps and protocols). Probably a consequence of the previous point, though
Can i achieve the same in case of an upgrade to TOS6? likely by only using the web interface?
Also, just a curiosity, i think i remember that in TOS5 the whole filesystem had rwx rights for Others. Is this changed in TOS6?
thanks in advance for your time
ciao!
F
Re: [Discussion] F4-212 - Is it advisable to upgrade from TOS5 to TOS6?
The functions available on TOS5 can almost all be implemented on TOS6. However, the TOS6 applicable to F4-212 is currently only available as a Beta package. For more detailed information and instructions, please refer to:
viewtopic.php?t=7888
Return to “System Update”
