Using the built in VPN in Network settings. NordVPN doesn't work. I've tried numerous of different options, even had Co-Pilot (GPT) to help me along the way. Credentials are correct and all other related settings. Even imported the .ovpn config file. When I try to connect, it fails. Can someone look into why the built in VPN in Network doesn't work?
Anyone else with the same issue?
[Help] NordVPN - VPN in Networking (TOS) broken
Plex F6-424 - 3x 12TB - 1x 4TB - 500GB SSD - 1TB NVME
Re: [Help] NordVPN - VPN in Networking (TOS) broken
Hello, we sincerely apologize for any inconvenience this may have caused! In the current version, there are indeed some known issues with connecting to NordVPN. Our team is actively working to resolve this, and a fix will be included in the next update. Thank you for your patience—please stay tuned for the upcoming release!ATOMFIX wrote: ↑30 Sep 2025, 13:40 Using the built in VPN in Network settings. NordVPN doesn't work. I've tried numerous of different options, even had Co-Pilot (GPT) to help me along the way. Credentials are correct and all other related settings. Even imported the .ovpn config file. When I try to connect, it fails. Can someone look into why the built in VPN in Network doesn't work?
Thank you for the quick update on this. Look forward to seeing it fixed soonHeliaWu wrote: ↑30 Sep 2025, 14:49Hello, we sincerely apologize for any inconvenience this may have caused! In the current version, there are indeed some known issues with connecting to NordVPN. Our team is actively working to resolve this, and a fix will be included in the next update. Thank you for your patience—please stay tuned for the upcoming release!ATOMFIX wrote: ↑30 Sep 2025, 13:40 Using the built in VPN in Network settings. NordVPN doesn't work. I've tried numerous of different options, even had Co-Pilot (GPT) to help me along the way. Credentials are correct and all other related settings. Even imported the .ovpn config file. When I try to connect, it fails. Can someone look into why the built in VPN in Network doesn't work?
