D4 SSD not recognized with four SSD - start loop
LittleWhite
France
Post by LittleWhite »
I am facing a strange problem with my D4 SSD. I am using it with KC3000 SSD from Kingston.
I was able to use the D4 SSD as expected with one, two, three or four SSD using Windows and Linux, using USB 4 or lower. Everything was fine when I use RAID 0 (with 2, 3 or 4 disks) and even RAID 5 with three SSDs (setup using Linux).
My problem is when I am using it with four SSD and RAID 6. After setting up the RAID, the disks somehow disappear/are no longer usable. If I reboot the computer, the disks will not appear (either on Windows or Linux). The D4 SSD is not detected at all. The fans from the D4 SSD starts and then stops and then again they starts and stops (sounding like the D4 SSD loop starts). This will also happen on Windows and even with a different computer.
If I remove one disk, the D4 SSD will be detected as expected. If I put back the disk, it will fail to start again. All the disks are still working as expected.
At some point, I could make the D4 SSD work again with four disks. And then, I retry the RAID 6 strategy and the D4 SSD failed again after syncing the disks.
Here the kernel log of the D4 SSD when it fails to start propoerly:
[ 47.956052] thunderbolt 0-2: new device found, vendor=0xb8 device=0x2463
[ 47.956059] thunderbolt 0-2: TerraMaster TDAS
[ 48.220030] thunderbolt 0000:67:00.5: 2: failed to enable TMU
[ 48.220813] thunderbolt 0000:67:00.5: 2:1: hop deactivation failed for hop 1, index 8
[ 48.220816] ------------[ cut here ]------------
[ 48.220818] thunderbolt 0000:67:00.5: path activation failed
[ 48.220868] WARNING: CPU: 11 PID: 1545 at drivers/thunderbolt/path.c:587 tb_path_activate+0x10b/0x490 [thunderbolt]
[ 48.220891] Modules linked in: rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device cmac algif_hash algif_skcipher af_alg qrtr bnep snd_sof_amd_acp70 snd_sof_amd_acp63 snd_soc_acpi_amd_match snd_sof_amd_vangogh snd_sof_amd_rembrandt vfat snd_sof_amd_renoir fat amd_atl snd_sof_amd_acp intel_rapl_msr snd_sof_pci intel_rapl_common snd_sof_xtensa_dsp snd_sof iwlmvm kvm_amd snd_sof_utils snd_pci_ps snd_amd_sdw_acpi kvm soundwire_amd mac80211 soundwire_generic_allocation snd_hda_codec_realtek irqbypass soundwire_bus crct10dif_pclmul snd_hda_codec_generic libarc4 crc32_pclmul snd_hda_scodec_component ptp snd_soc_core polyval_clmulni pps_core polyval_generic snd_hda_codec_hdmi ghash_clmulni_intel snd_compress sha512_ssse3 ac97_bus sha256_ssse3 snd_hda_intel snd_pcm_dmaengine snd_intel_dspcfg sha1_ssse3 btusb iwlwifi snd_intel_sdw_acpi snd_rpl_pci_acp6x aesni_intel btrtl snd_acp_pci snd_hda_codec gf128mul btintel spd5118 snd_acp_legacy_common btbcm crypto_simd snd_hda_core btmtk cryptd snd_pci_acp6x snd_hwdep r8169 rapl
[ 48.220948] psmouse pcspkr snd_pci_acp5x sp5100_tco snd_pcm cfg80211 thunderbolt k10temp realtek bluetooth snd_rn_pci_acp3x snd_timer mousedev mdio_devres snd_acp_config snd i2c_piix4 snd_soc_acpi joydev libphy ccp rfkill snd_pci_acp3x soundcore i2c_smbus i2c_hid_acpi amd_pmc i2c_hid mac_hid i2c_dev crypto_user dm_mod loop nfnetlink ip_tables x_tables ext4 crc32c_generic mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core crc32c_intel cec video crc16 nvme_auth i8042 wmi serio
[ 48.221014] CPU: 11 UID: 0 PID: 1545 Comm: pool-1 Tainted: G W 6.12.41-1-MANJARO #1 d17471dfc5ed1d417a0dac1b8773fcab12b83227
[ 48.221017] Tainted: [W]=WARN
[ 48.221018] Hardware name: PELADN HO4/HO4, BIOS 5.29 07/26/2024
[ 48.221019] RIP: 0010:tb_path_activate+0x10b/0x490 [thunderbolt]
[ 48.221027] Code: 01 00 00 48 85 ed 0f 84 d8 00 00 00 48 81 c7 c8 00 00 00 e8 77 80 11 dd 48 89 ea 48 c7 c7 f8 e6 b1 c1 48 89 c6 e8 55 fc 7f dc <0f> 0b 48 8b 44 24 08 65 48 2b 04 25 28 00 00 00 0f 85 5f 03 00 00
[ 48.221029] RSP: 0018:ffffd22e429d3980 EFLAGS: 00010246
[ 48.221031] RAX: 0000000000000000 RBX: 00000000ffffff95 RCX: 0000000000000027
[ 48.221032] RDX: ffff895981fa1888 RSI: 0000000000000001 RDI: ffff895981fa1880
[ 48.221033] RBP: ffff895342336ec0 R08: 0000000000000000 R09: 00000000ffffefff
[ 48.221034] R10: ffffffffa045d540 R11: ffffd22e429d3818 R12: 0000000000000028
[ 48.221035] R13: ffff8953a7a68ec0 R14: 0000000000000001 R15: 0000000000000000
[ 48.221036] FS: 00007f7aa73fe6c0(0000) GS:ffff895981f80000(0000) knlGS:0000000000000000
[ 48.221038] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 48.221039] CR2: 0000562d4e846000 CR3: 000000011dcfa000 CR4: 0000000000f50ef0
[ 48.221040] PKRU: 55555554
[ 48.221041] Call Trace:
[ 48.221042] <TASK>
[ 48.221045] tb_tunnel_restart+0x9e/0x190 [thunderbolt 34a8463d1d1133e5d940691c5a8983f86107bc2f]
[ 48.221056] tb_tunnel_pci+0x1ad/0x3b0 [thunderbolt 34a8463d1d1133e5d940691c5a8983f86107bc2f]
[ 48.221066] authorized_store+0x287/0x2c0 [thunderbolt 34a8463d1d1133e5d940691c5a8983f86107bc2f]
[ 48.221074] kernfs_fop_write_iter+0x138/0x1f0
[ 48.221079] vfs_write+0x28d/0x470
[ 48.221084] ksys_write+0x75/0xf0
[ 48.221086] do_syscall_64+0x7b/0x190
[ 48.221090] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221093] ? get_signal+0x726/0x890
[ 48.221097] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221098] ? arch_do_signal_or_restart+0x40/0x280
[ 48.221103] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221104] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 48.221107] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221108] ? do_syscall_64+0x87/0x190
[ 48.221110] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221111] ? get_signal+0x726/0x890
[ 48.221114] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221115] ? arch_do_signal_or_restart+0x40/0x280
[ 48.221119] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221120] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 48.221122] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221123] ? do_syscall_64+0x87/0x190
[ 48.221125] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221126] ? arch_do_signal_or_restart+0x40/0x280
[ 48.221130] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221131] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 48.221133] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221134] ? do_syscall_64+0x87/0x190
[ 48.221136] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221137] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 48.221139] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221141] ? do_syscall_64+0x87/0x190
[ 48.221142] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221144] ? do_syscall_64+0x87/0x190
[ 48.221145] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221147] ? do_syscall_64+0x87/0x190
[ 48.221148] ? srso_alias_return_thunk+0x5/0xfbef5
[ 48.221150] ? irqentry_exit_to_user_mode+0x2c/0x1b0
[ 48.221151] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 48.221154] RIP: 0033:0x7f7aa8c9f042
[ 48.221172] Code: 08 0f 85 d1 40 ff ff 49 89 fb 48 89 f0 48 89 d7 48 89 ce 4c 89 c2 4d 89 ca 4c 8b 44 24 08 4c 8b 4c 24 10 4c 89 5c 24 08 0f 05 <c3> 66 2e 0f 1f 84 00 00 00 00 00 66 2e 0f 1f 84 00 00 00 00 00 66
[ 48.221173] RSP: 002b:00007f7aa73fdb98 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 48.221175] RAX: ffffffffffffffda RBX: 0000561e87bc9fe0 RCX: 00007f7aa8c9f042
[ 48.221176] RDX: 0000000000000001 RSI: 00007f7aa73fdc80 RDI: 000000000000000a
[ 48.221177] RBP: 00007f7aa73fdbc0 R08: 0000000000000000 R09: 0000000000000000
[ 48.221178] R10: 0000000000000000 R11: 0000000000000246 R12: 000000000000000a
[ 48.221179] R13: 0000561e87bd23e0 R14: 0000000000000000 R15: 00007f7a9c00cac0
[ 48.221182] </TASK>
[ 48.221183] ---[ end trace 0000000000000000 ]---
[ 48.221184] thunderbolt 0000:67:00.5: 0:5 <-> 2:3 (PCI): activation failed
[ 48.221376] thunderbolt 0000:67:00.5: 2:3: PCIe tunnel activation failed, aborting
[ 48.221675] thunderbolt 0-2: device disconnected
TMlinda
Re: D4 SSD not recognized with four SSD - start loop
Post by TMlinda »
LittleWhite wrote: 27 Sep 2025, 21:23
This is a power adapter issue. We recommend contacting LiveChat on the official website to have the power adapter replaced.
https://www.terra-master.com/
Return to “USB Series”
