[Help] Docker container folder issues
Discussion about Docker
bkfootball14
Post by bkfootball14 »
Was curious if anyone has been able to successfully use tdarr in a container on TOS6. I seem to have an issue where I am unable to have tdarr find my plex library. My library is in the Volume1/PlexMediaFolder/Movies....etc structure. I mapped the container to here /PlexMediaFolder:/media
I have double checked the folder permissions, PUID/PGID are both =0.....i am pretty much at a loss at this point of how to get this container to find my media files. Any advice would be appreciated....
Thanks!
TMlinda
Re: [Help] Docker container folder issues
Post by TMlinda »
bkfootball14 wrote: ↑27 Sep 2025, 01:51
We will verify this issue in our lab.
EthanLiu
Post by EthanLiu »
What image version are you using? Please send us the image name or the complete Docker Compose project file and we will arrange for verification as soon as possible.
bkfootball14
Here is the docker compose I am using for the container
services:
tdarr:
image: haveagitgat/tdarr:latest
container_name: tdarr
restart: unless-stopped
ports:
- "8265:8265" # Tdarr Web UI
- "8266:8266" # Tdarr Server port
- "8267:8267" # Tdarr Internal comms
environment:
- TZ=America/New_York
- PUID=0
- PGID=0
volumes:
- /dockerappsdata/tdarr/server:/app/server
- /dockerappsdata/tdarr/config:/app/configs
- /dockerappsdata/tdarr/logs:/app/logs
- /plexmediafolder:/media
EthanLiu
Post by EthanLiu »
bkfootball14 wrote: ↑29 Sep 2025, 20:42
You need to fill in the complete path, for example:
    volumes:
      - /Volume1/dockerappsdata/tdarr/server:/app/server
      - /Volume1/dockerappsdata/tdarr/configs:/app/configs
      - /Volume1/dockerappsdata/tdarr/logs:/app/logs
      - /Volume1/plexmediafolder:/media
bkfootball14
I have tried that configuration and it still does not map to the folder in the docker compose
TMbuddy
Post by TMbuddy »
bkfootball14 wrote: ↑30 Sep 2025, 20:49
Hello! To better resolve the issue, please provide a screenshot of the non-functional behavior. Additionally, kindly check your configuration and verify whether the mounted directory has the necessary permissions.
Return to “Docker”
