"apt" usage
DBa
Germany
"apt" usage
Post by DBa »
Hi all,
it looks like TOS6 has a dpkg and apt installed, with sources.list pointing to Ubuntu jammy.
Is using apt in the usual way (especially apt upgrade) going to break my system?
Herewerare2024
Re: "apt" usage
Post by Herewerare2024 »
It won't really work. It will find updates but fail to apply them. This is linked to the account framework and no access to actual root. If you want to install packages that are not included in the GUI list... reinstall with a different OS... likely a regular linux install and then trim and customize as you like. The TOS OS is difficult to mess with and it's far easier to just run an alternative linux install.
Hypnotism8031
Italy
Re: "apt" usage
Post by Hypnotism8031 »
On TOS6 it works like a charm :D :D
install nano without any problem.
(F2-425 Plus)
Return to “System Update”
