WakeonLan CLI
rvescovi
Italy
WakeonLan CLI
Post by rvescovi »
Hi all, is it possible to have installed the CLI wakeonlan, so we can script a wake on lan to other network devices?
Thanks,
Re: WakeonLan CLI
Is the Wake on LAN feature built into TOS not meeting your needs? (Control Panel-General Settings-Hardware & Power-Power)
If this CLI wakeonlan is available on Ubuntu system, it should also work smoothly on TNAS (TOS 6 and later version).
However, we cannot provide you with specific operational steps.
rvescovi
Italy
Re: WakeonLan CLI
Post by rvescovi »
the wakeonlan I'm referring is the command line to send wakeonlan packets to other devices in your local network, so you can wake up cameras, servers, ...
I saw is not installed in the TOS, I tried with apt without success due it requires an admin role.
FredMutter
France
Re: WakeonLan CLI
Post by FredMutter »
rvescovi wrote: 24 Sep 2025, 03:25
it should work. Remove the admin word from the command if you wrote it
rvescovi
Italy
Re: WakeonLan CLI
Post by rvescovi »
Hi, at the end I build an UBUNTU docker image with ETHERWAKE installed so, I can use WAKEONLAN cli command, without any changes to the original TOS OS
