sync NAS with external WEBDAV ( Kdrive from infomaniak)  [SOLVED]
jdcesari
French Southern Territories
Post by jdcesari »
- i tried to sync my TNAS f4ssd public directory to an external cloud : Kdrive from infomaniak.
It uses WEBDAV protocol.
i tried to sync with duple backup - it is painful to configure and above it doesnt sync.
it creates somes files on kdrive.
But it changes the file name, the directories etc.... i did not suceed in using it normaly
- why not add the webdav feature in cloudsync ( i was as this in me previous QNAP), i think it gonna be easier.
or anyway to make a simple copy of my NAS to a WEBDAV drive..
Re: sync NAS with external WEBDAV ( Kdrive from infomaniak)
What version of your system are you using? If it's the latest TOS 6, you can go to the Remote Folder in the TOS Control Panel and select Cloud Drive, which includes the functionality to mount a WebDAV server.
jdcesari
Post by jdcesari »
still have the problem
on all my alternative services, i have no probelm with WEBDAV ( qnap, filestash, raidrive).
Could you let us know the WebDAV connection configuration for TNAS and the configuration for any other system's WebDAV connection? (Excluding sensitive parts such as account names and passwords). This might help us identify something.
jdcesari
Post by jdcesari »
i think i suceeded
but if i use dudle backup, it doesnt syncronize, it copies again and agin the files
how to only syncronize ?
You may be using 'multi version mode', please reconfigure to 'mirror mode' to meet your usage needs.
jdcesari
Post by jdcesari »
in this case , i can not select WEBDAV
webdav is not avalable in mirror MODE
only the cloud are suggested.
In view of your situation, we recommend that you mount the directory on the NAS via WebDAV to Kdrive, which will allow you to use TFM Backup to implement image backup/synchronization.
jdcesari
Post by jdcesari »
it is not very easy
beacuse it is full volume and not only some directories..
the best way is including WEBDAV in cloudsync
Return to “CloudSync”
